Ideas on C2 underhood noise during warmup - help! - NCRS Discussion Boards
  • Timothy B.
    • January 1, 2004
    • 438
    I have been experiencing a noise under the hood that I haven't been able to figure out. My 67 327 vert makes a strange underhood noise during initial warmup and acceleration. Once the car is driven only a few miles the noise dissipates. The sound is hard to describe, but is similar to a mid frequency vibration or maybe even an exhaust leak. The noise appears when the car is not yet warmed up, regardless of actual ambient temps. After a short distance, it goes away.
    I recently replaced the exhaust pipes front and rear, new exhaust manifold gaskets, new pipe to manifold donuts, etc. I had noticed the noise prior to the pipe replacement and hoped that new parts would take care of it. I used no sealer between the front and rear pipes.
    Anyone experienced a noise similar to this and if so what turned out to be the cause? Can the pipe joint between the front and rear pipes make such a noise during warmup only?
  • Mike Geary
    Re: Ideas on C2 underhood noise during warmup - he
    Have you checked the heat riser? It can make some pretty weird noises when cold if it's cracked.
    • Timothy B.
      • January 1, 2004
      • 438
      When I replaced my exhaust pipes, I removed the heat riser and installed the blank heat riser spacer from the FI cars. So, I know that's not the problem. Thanks for the suggestion however.
      • Wayne P.
        • August 31, 1975
        • 1025
        Sometimes bearing noises, like the alternator, can do this before they completely fail.
        • Gerard F.
          • June 30, 2004
          • 3806
          Could it be your belts slipping? Just a thought.
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
          • Rob A.
            • December 1, 1991
            • 2126
            Tim,
            Next time you start the engine up cold, putone end of a rubber hose on the alternator and the other against your ear. If that's the noise source, you'll hear it magnified. The bearings will sound worse during warmup, if they are going bad.
