'54 engine nr question - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12740
    I've found a potential # matching enging '54 car to buy but the ad states the engine numbers are: (Pad #0447425F54YG) cast #3835913. The judging manual suggests the cast # should be 3835911. Who is right, who is wrong?
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12740
    Re: '54 engine nr question
    See link below of the car I had in mind. What I can make of the photo's the head isn't correct #241 as well...
    Your opinions are highly appreciated...
    greetings,
    Rob
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi
    Rob.
    • mike mccagh
      911 is what you want. mike
      • Dan A.
        • May 31, 1974
        • 1074
        Google search indicates 3835913 is a 1954-55 casting number for a 235 cu. in. 6 cyl. head. But not for Corvette, they were 3836241.
        • Robert S.
          • July 31, 2004
          • 377
          Rob, here are the numbers you should be looking for...I got these the a Restorer article.
          1954 CORVETTE
          Serial Number Range E54S001001 through E54S004640
          Engine Identification Code Suffix - F54YG
          Engine Block Casting Number - 3835911
          Cylinder Head Casting Number - 3836241
          Rear Axle Identification Code - MW
          Fuel Pump - AC Model 9797, #5592675 (very first cars)4132, #5593235 (all later cars)
          Carburetors - Carter Model YH 2066SA, #3706989
          Radiator - 3130953
          Battery - Delco 15AA6-W
          Starter - 1108035
          Generator - 1102793
          Voltage Regulator - 1118725 1st design
          1118827 2nd design
          Coil - 1115394
          Distributor - 1112314
          Bob
