C1 Heater Motor Wire - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    Can anyone supply me with the correct gauge wire with the correct connector for my heater blower motor? Mine has been chewed up by some kind of critter and I don't have either the connector or enough brown wire to repair so it will need total replacement. Thanks
  • Robert S.
    • July 31, 2004
    • 377
    Re: C1 Heater Motor Wire
    Lectric has them.
    www.LectricLimited.com
    Bob
    • Justin B.
      • March 1, 1996
      • 478
      I did not see the part number at their website...did you see it?
      • Robert S.
        • July 31, 2004
        • 377
        Oh, I didn't realize you have one of those "new" C1's.
        No, I didn't see one for a '58. And most of the other vendors seem to only have up '57. I looked at the wiring diagram in ST-12. All I could see there was a 14 guage Brown wire from the fuse panel to "heater". Doesn't say if its the heater motor or switch.
        Maybe someone with a '58 might jump in with more help.
        Good Luck,
        Bob
        Bob
        • scott scearce
          According to the wiring diagram this is indeed a 14 gauge wire; at least on the '60 which should be similar to the '58. The connector is part of the heater switch/defroster control assy. part#3140543
