1967 valve covers - NCRS Discussion Boards
1967 valve covers
  • Dale S.
    • November 12, 2007
    • 1224
    1967 valve covers
    Happy New Year! Could some one explain the difference between the 1967 scripted valve covers and the earlier one's. I saw in one of the threads that the end was different. I looked in the archives and could not find it. Dale
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 1967 valve covers
    Dale - the covers are the same other than sometime in mid production in the 66 model year the mold cracked and there is a line through the "o" in Corvette....Craig
    • lyndon sharpton
      so all produtions covers would have this crack? even the over the counter ones?
      • mike mccagh
        pre-mid 66 prod year covers, whether service or production, will not have the casting flaw. post mid 66 service and production cover will demonstrate the flaw. mike
          Dale -
          The "scripted" stamped sheet metal valve covers for '67 had the ends laid back at about a 20-degree angle from vertical; '66 and earlier stamped valve covers had the ends almost vertical.
          • Peter L.
            • May 31, 1983
            • 1930
            John - Happy New Year. Nice picture. The ones on my base motor '67 don't look as nice but they are the same configuration. Curious about your message. I read it as the '67 sb base Corvette engine CHEVROLET script valve covers are different in configuration at the ends then prevoius years; but I had thought that the script covers used on the Chevrolet 283 engines for a number of years proir to the 1967 Corvette engine application were the same configuration. So my question is "are the '67 Corvette CHEVROLET script ones unique?" Pete
              • 43221
              Dale-----
              If you're talking about the ALUMINUM "Corvette" scripted valve covers, then the answer is as others have described.
              If you're talking about the STAMPED STEEL scripted covers, it's like this: the L1959-61 scripted covers were different from the 1967 Corvette scripted covers as John described. However, the 1967 Corvette scripted covers were not unique to 1967 Corvettes. They can be found on passenger car 283 engines from about 1965 through 1967.
                • 43221
                Pete-----
                While you were asking the question, I was writing the answer. See my post below.
                • Peter L.
                  • May 31, 1983
                  • 1930
                  Joe - Thanks and Happy New Year. Pete
                  • Dale S.
                    • November 12, 2007
                    • 1224
                    Thank you one and all! Dale
