350 main cap bolts/studs - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    Anyone find quality studs for a half way reasonable price?
    I'm obviously going to be putting a windage tray where no windage tray has been before.
    So far the best price I've found is $45.00
    Chuck
  • Tom P.
    • April 1, 1980
    • 1815
    Re: 350 main cap bolts/studs
    I've always used the stock GM studs for a 350 with a windage tray, and never had a problem. It takes 5.
      • 43222
      Chuck-----
      The GM studs are GM #14087508 and currently GM list for $11.15/each. From a discounting GM dealer you ought to be able to get these for about $8.50/each, so it should cost you about the price you've found for a set of 5. I don't think that you'll find a set of known-quality studs for much less than this.
      Beyond that, though, what year engine, oil pan, and oil baffle are you proposing to install these with? Not all combinations will work.
      • Tom P.
        • April 1, 1980
        • 1815
        I might add that you CANNOT use the GM studs with aftermarket, splayed 4bolt main caps. The caps are toooooooooooo tall for the GM studs!
        • Tom P.
          • April 1, 1980
          • 1815
          I just checked gmpartsdirect.com and they have them priced at $6.35.
          • Scott Marzahl
            I like the ARP fasteners, they have a nice set of studs.
            • Clem Z.
              • January 1, 2006
              • 9427
              that price is dealer cost and they make
              the profit on the S&H
              • Chuck R.
                • April 30, 1999
                • 1434
                Re: Thanks for the responses
                I'll check out GM and hopefully my local speed shop when ever they open up.
                Thanks again,
                Chuck
