Re: C2 Front Spring Install Help Please - NCRS Discussion Boards
+ More Options
Posts
  • Chuck R.
    • April 30, 1999
    • 1434
    I picked up one of those expensive Harbor Freight internal spring compressors, canned everything but the lower hook portion because it was already offset for the coil's spiral and used the 5/8" thread stock method.
    I double nutted one end of the thread stock and then tacked the end nut to the thread stock with the welder so I didn't have to worry about them spinning off, then I put on two large flat washers (slathered with heavy grease) and then the hook.
    I then ran the this assembly up through the spring and up through the tower again dropping two heavily greased flat washers over the thread stock and winding two nuts (tacked together and matched to the treads) down onto them.
    My reasoning for the double nuts welded together was to have more threads pulling reducing the chances of the threads stripping and the whole shooting match flying back out of the tower.
    I also had a heavy duty ratchet type load binder strap pulling in-board from the opposite side just in case things suddenly came free to contain the spring.
    The nice thing about the strap is that it takes up virtually no space between the coils when they're compressed.
    As soon as I had the tension just barely off the lower A-arm, I put the floor jack under it for safety's sake and then loosened the lower ball joint nut only about two full turns. I then backed the lower spindle ear with a heavy hammer and belted the opposite side with another heavy hammer until it dropped free but held in place by the ball joint nut.
    Then it was a matter of dropping the A-arm out of the way and slowly backing off on the thread stock.
    I was surprised at how easy the thread stock compressed the spring, but I'll tell you that I was guarding myself against that spring busting free at any second so I made good and sure that I was working from the back side of the potential path the spring would take "if" it decided to take a ride on me.
    The lower A-arms on my 68 had alignment holes to visually verify that the end of the coil was positioned correctly, does C-2s have this? Just curious.
    Good luck and be safe,
    Chuck 32205
  • Joe C.
    • August 31, 1999
    • 4598
    Tally Ho!
    Nice job, Chuck. It's always good to hear how we go about "engineering" solutions to various problems.
    I use a similar setup, with 2 straight sections of old rear leafspring between the coils. I don't double nut, though. IMHO, the double nut will create an interference fit, with increased friction, unless the 2 nuts are perfectly aligned.
    Joe
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Perfectly aligned Joseph
      Or at least as close as these ole pupils will let me get them
        Chuck -
        The front springs are positioned only at the top of the spring tower, as shown in the A.I.M. (3/8" from the stop); the hole in the spring pocket in the lower control arm isn't for spring positioning - it's just a drain hole.
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Brain f_rted again
          Sorry John, my dyxlexia kicked in. I was thinking spring tower and typing lower control arms.
          Thanks for the clarification.
          Chuck
