notice anything unusual? *NM* - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    #31
    Correct!!! Guy on the left...is Carrol Shelby *NM*
    • Mike E.
      • February 28, 1975
      • 5138
      #32
      Re: 4360
      Joe--
      The double ballast resistor--purpose?
      • Joseph T.
        • April 30, 1976
        • 2074
        #33
        Re: notice anything unusual?
        Bill...The passenger side mirror was also trasferred from the Sebring car along with the emblems and drivetrain. You don't see the drivers side mirror on the 54..because the drivers side door is off the car.
        Joe
        • Joseph T.
          • April 30, 1976
          • 2074
          #34
          Meyer Speedway Special..Eb Rose
          Mike
          Your guess is as good as mine. Maybe someone like Clem..might take a stab at it!
          George Moore did the transplant. I suspect it was also transferred from the 57. George also went on to wrench for Eb Rose who drove at Indy in 61/62 & 63
          Joe
          • mike mccagh
            #35
            Re: Correct!!! Guy on the left...is Carrol Shelby
            joe: was the picture you posted taken ata Cumberland national run-off and if so, what year? our NRA website with the cumberland historic photos is temporarily down so i can't look and see if its a cumberland shot. As far as the ballast resistors, bet the original (can't see the delco resistor in your picture well enough to tell if its a 57 resistor ) took a crap. the ballast resistor closest to the engine is a generic. i'd have by-passed the resistor and run a full 12 v to the points if i were running the setup back then and did't expect to have to run more than a hour or so on 12v. mike
            • Joseph T.
              • April 30, 1976
              • 2074
              #36
              Mike..The Shelby Corvette Picture
              Is at Cumberland '57..I would have to check my file for the date..but as I recall it was about June/July 57..the SCCA event. I have the results around somewhere..
              Eb brought the Bill Mitchell SR2 and the 2 Black/Pink 57's. Carrol was there with team Maserati...but also drove for Eb in B bracket.
              Regarding the resistor..would it have made a differance since ..George was installing a 12 volt engine into a 6 volt car?
              • Clem Z.
                • January 1, 2006
                • 9427
                #37
                dual resistors
                if my high school electric class does not fail me i think 2 resistors in parallel would allow the same voltage thru but you would have a backup if one resistor opened up and the voltage would keep flowing.
                • Mike E.
                  • February 28, 1975
                  • 5138
                  #38
                  Re: dual resistors
                  One reason I asked--my Gulf Oil 62 was run by Gulf with 2 coils--both mounted--one as a backup so that Thompson or Yenko could simply switch the center wire and be back on the track ASAP.
                  • William C.
                    • May 31, 1975
                    • 6037
                    #39
                    Re: dual resistors
                    If they are wired in parallel, the effective resistance is half, so the voltage to the distributor and coil would be higher than the standard configuration. (Hotter spark)
                    Bill Clupper #618
                    • Joseph T.
                      • April 30, 1976
                      • 2074
                      #40
                      Re: dual resistors
                      Mike
                      That is interesting..because I recall hearing about coil failures. Sebring cars had to get back to the pits on their own or pushed by the driver. Sounds like a good idea to have a spare coil set up in place of failure.
                      • Joseph T.
                        • April 30, 1976
                        • 2074
                        #41
                        Re: dual resistors
                        Maybe old George..was a smarty...dealing with a 6 volt car trying to make adjustments.
                        • Frank C.
                          • January 1, 1986
                          • 277
                          #42
                          Mike....back in my early drag racing days we had the resistor on a toggle switch, and just when ready to leave would turn it on for 12v but the points were only good for 4 or 5 passes.
                          • Mike E.
                            • February 28, 1975
                            • 5138
                            #43
                            Re: dual resistors
                            Joe--
                            I have a picture of Dick Thompson on his knees on the cowl, bent over fixing something underhood on my car back in 62--can't tell which track, but I knew that at Sebring they could repair it on the course (no crew could go out) or limp it back to the pits.
                            • Kent K.
                              • December 1, 1982
                              • 1139
                              #44
                              White convertible tops were not seen on 53-55 from my memory.
                              Happy New Year!!!!!!
                              Kent
                              Kent
                              NCM Founder - Member #718
                              • Clem Z.
                                • January 1, 2006
                                • 9427
                                #45
                                FI drive cable???
                                those race cars did not use the outer cover on the drive cable so if it broke it could be changed quickly.
