C# Carburetor idle solenoid - NCRS Discussion Boards
  • Jeff A.
    • December 1, 2001
    • 95
    On an automatic, Holley equipped 350/270 hp the AIM shows an Idle solenoid to control dieseling. It has one terminal, but the wiring diagrams don't show a wire to connect to it. What color wire should attach to this and where does it come from. I assume the circuit is completed by grounding to the engine. Thanks.
  • george romano
    Re: C# Carburetor idle solenoid
    Should be a tan wire.
    The ground path is where it bolts to the carburator like you said.
    I believe 71 also has 2 vacuum hoses on it as well, but........
    George
      • 11652
      What is an automatic, Holley-equipped 350/270? Chevrolet did not make such an engine/carb/transmission combination, at least not in a Corvette.
      And, what year are you interested in?
      Patrick
