Power Steering component rebuild ?? - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    I am in the process of rebuilding my steering gearbox awaiting parts for now. I am considering rebuilding my pump and control valve. My cylinder needs to be cut open and have a new chromed shaft installed so it will be sent out for rebuid. I know I saw articles, either in a corvette magazine or the restorer, on the rebuild of the control valve and pump. I cannot find these articles. My shop manual has the procedure for both, but I would like an aricle written by one of us, more detailed. Somewhere I saw where the pump usually only needs its filter cleaned and new seals. I have never driven this car. It was not running when I bought it. NAPA has the seal kits for both. Part numbers are; Control Valve: 7-137 , Pump: 7-132. Prices for each are 17.99 and 17.39 respectively, without any discounts applied. I am certain some of you have rebuilt these components. Is this a pretty straightforward process? Any suggestions on your experiences appreciated. Thanks! Dick Gutman
  • Terry F.
    • September 30, 1992
    • 2061
    Re: Power Steering component rebuild ??
    They are very straight forward and I would not hesitate to use your overhaul manual. They are pretty complete. If you have your original pump, that is good. They are a little different internally compared to passenger cars as I remember. So, look at it closely. I think there will be a special blurp in your manual regarding the corvette differences. The controle valve is the same. If you have a decent work bench and tools you can do both. Terry
    • Mac Peppers
      i'm presently working on both of these items. the pump is a piece of cake, if your shaft bushing is ok, otherwise it's only a few o-rings and a shaft seal. i can send you a picture of the internals if you want to take a look at what you're getting into. the valve also seems easy enough, just more small pieces. i've got mine back together, but i had one piece that i wasn't 100% sure of the location. my shop manual doesn't show the internals, could you tell me what manual you have that showes it?
      thanks,
      mac
      • Stephen P.
        • September 30, 2002
        • 116
        Dick, I've got a copy of an article on rebuilding power steering that was on the Corvettemagazine.com website. I can't get that website to come up, but I've got a copy of the article in pdf format, along with some other miscellaneous power steering information I've gathered. If you would like a copy, please sent me an email. I'll be out of town over New Years, so it may be next week before I can respond.
        Steve Phillips
        • Mac Peppers
          Steve,
          could you copy me when you send that article. i got the website to come up, but couldn't find the article. i rebuilt my valve without a manual and would like to check my work before i install it. i'm at britstar@hopper.net
          thanks,
          mac
          • Ed R.
            • June 30, 1991
            • 55
            May I have a copy as well? My address is eraemer@hotmail.com
            Thanks very much.
            • Roger S.
              • May 31, 2003
              • 262
              I believe there are a couple articles at CorvetteFAQ.com about rebuilding the power steering system.
              Roger
