B/W M20 T 10 - NCRS Discussion Boards
B/W M20 T 10
  • nancy charles
    B/W M20 T 10
    what is the best way to tell the diff. between a close ratio M 20 trans. from a wide ratio m 20 BORG WARNER ? does the close ratio have any rings on the imput shaft ? NEED some help ???????????? thanks all .
  • Pieter Kanitz
    Re: B/W M20 T 10
    Hi just give me the no, that is to be read on the transmission tag.
    something like 3870354 (4spd M20 WR 300,350,390HP)
    a muncie has 7 bolts at the side cover
    a T-10 has 9 bolts at the side cover
    regards pieter
    • Mike McKown
      Re: B/W M20 T 10
      Put the transmission in low gear. Turn the OUTPUT shaft one turn. If the INPUT shaft turns 2.25 times, it's a close ratio. If it turns 2.5 times, wide ratio.
      • Verne Frantz
        Re: B/W M20 T 10
        Nancy,
        The wide ratio had one groove cut around the input shaft. Also, if the side cover is original, there will be an "A" cast after the date code. I haven't the foggiest idea why the side cover would be different for a wide ratio, but that's been my observation after looking at a lot of T-10s.
        Verne
