Is it necessary to unbolt the end of the spring from the trailing arm to install the strut rod?
I removed one of the rear shock mounts (new)to file off some material so that the mount would seat properly in the spindle mount. When I tried to reinsert the shock mount, I could not properly align the end of the strut in the spindle mount in such a way as to avoid damaging the shock mount threads. So I removed the cam assembly from the other end of the strut rod and and removed the rod entirely. With the cam end of the strut out of it's bracket, it is easy to slide the shock mount into place. But with the shock mount end in place, the cam end does not align properly. When I first installed the struts, the spring was not yet attached to the trailing arms. I have the half shaft detached from the differential yolk.
Steve
Steve
