flywheel/bellhouse combination..62 - NCRS Discussion Boards
  • randy maurstad
    ive got a 62 with flywheel # 3714463.. i understand the correct bellhousing is 3779553.. is there a less expensive more easily found bellhousing i can use?
    Re: flywheel/bellhouse combination..62
    Randy -
    Functionally, you could use casting #3733365 (used on late '56-'59); it's cast iron instead of aluminum. You could also use #3764591 ('60 only), aluminum, but it's harder to find than the correct #3779553.
