1960 Fuel Injection unit Dates?? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 941
    I need a correct fuel injection unit for my big brake 60. I know it should have a 7017320 unit, but should I look for serial numbers or date codes? The judging manual says no corelation, but I think there should be a range? I recieved a 58 unit with the car and I know that must go. Any help or suggestions would be appreciated.
  • Bill Lacy
    Re: 1960 Fuel Injection unit Dates??
    Bill
    Try John DeGegory. He treated me very well on my 63 unit.
    • mike mccagh
      ditto on john DeGregory of greensburg, pa. he ads in driveline. he'll probably take the 58 unit on trade. Jerry Bramlett , who is a frequent poster on this forum, also has good reputation . good luck with the ole 60. mike
      • Loren L.
        • April 30, 1976
        • 4104
        You KNOW you need a7320? VIN? *NM*
        • William B.
          • April 30, 1975
          • 941
          Re: You KNOW you need a7320? VIN?
          I am in contact with John D., but he has no unit for me at this time. I will have him rebuild it when I find a unit. It's just that the serial numbers confuse me and I guess everyone else? maybe someone has a 60 unit that would trade for a 58, probally dreaming, but I'll keep looking. Thanks for the responses.
          • mike mccagh
            call John Gratta in mt airy md. he rebuilds them and may swap .Did you check with brian Futo, the FI tech advisor listed on p 3 of the Restorer mag? mike mike
            • William B.
              • April 30, 1975
              • 941
              Thanks, Mike, I'll contact both of them.
              • Mike E.
                • February 28, 1975
                • 5138
                Bill, there is a correlation between FI unit serial number and the build date of the car, and it is more significant than early car--early unit, late car, late unit.
                The first 7320 unit was serial number 1001. There were 759 hi-horse fuelies in 60, and 10,200 cars. That's roughly 1 in 15 being a fuelie. Take your VIN, divide by 15, and add to 1001, and that will give you a range to look for.
                (e.g. your VIN is 7560, divided by 15 is 504, added to 1001 is 1540.) I'd look for a unit (or have a tag made) that is between 1500 and 1600 for that car.
                Hope this helps.
                Mike Ernst
                • mike mccagh
                  "have a tag made" !!!! good god, you've gotta be kiddin rev. mike
                  • William B.
                    • April 30, 1975
                    • 941
                    Thank You, Mike and Mike! *NM*
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      All of these posts are interesting - especially
                      in view of the fact that I was TRYING to get to the RUNNING CHANGE from a 7300 to a 7320 and when it occurred. Maybe there's still room in NCRS for research......
