'69 L71 Starter questions - NCRS Discussion Boards
  • Steven C.
    • October 23, 2006
    • 186
    I am attaching the starter to my engine. I have two questions:
    1. The starter has holes for three mounting bolts, but only 2 line up with the holes in the engine, and these two are offset, not the two that are closest to the flywheel. Is this correct for the 427, and is the other hole in the starter for a different configuration? There appears to be a tapped hole in the vicinity on the engine, but it won't line up when the other two bolts are in place.
    2. I clumsily broke off the stud from the back of the starter used to mount the rear starter bracket to the engine. Is this a grounding lug, a short stud, or a long stud that goes all the way through the starter? I'm asking for purposes of repair, the stud is broken off flush with the nut that was underneath the bracket. I'm ready to remove that nut tonight, unless I'm risking damage to internals.
    Thanks in advance for helping me move (albeit slowly) toward resuurecting this project car.
    Steve
  • Jim T.
    • March 1, 1993
    • 5351
    Re: '69 L71 Starter questions
    For the broken stud, visit a rebuild shop or recycle yard and get another one. This bolt runs the length of the starter and is one of the two long bolts that hold the nose, body, and end together. The support brace should be installed. Simple fix for you. Off-set holes in starter noses for the larger flywheel/flexplate application. If the inline starter nose is used it is for the smaller flywheel/flexplate. The main part of the starter does not care what nose is used.
    • Steven C.
      • October 23, 2006
      • 186
      Thank you Jim Trekell! *NM*
