Hood weather strip advise . Please - NCRS Discussion Boards
  • don 42616
    I have a new hood weather strip 6' long from paragon. Please look at photo & tell me how long it is supposed to be & is it glued in the back crevice? Thank you , Don
  • don 42616
    Re: Hood weather strip advise . Please
    P.S I did look at my AIM & JG but did not find definitive answer. DON
    • don 42616
      (Message Deleted by Poster)
      • Stephen L.
        • May 31, 1984
        • 3158
        The weatherstrip is glued in place in the crevice. It should turn the corner and be about 3/4" beyond the holes in the hood. There is a "pin" that should be installed in the weatherstrip and into the holes to keep the ends in place.
        Typically yellow 3M weatherstrip adhesive is used for installation. More than likely you need to trim the strip to length....
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          If your hood is an original (it looks like it could be), as Steve mentioned,
          look for the hole for the plastic push-pin on the outside edge of the inner hood. This should be forward of the hood pin an inch or two or more, position varied, then trim the strip about 1/4" forward of that hole.
          Incidentally, the amber/honey colored adhesive was applied rather eradicly with a 1-1/2" brush.
          H. a. N. D.
