can you identify this big tank? *NM* - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
  • Mike E.
    • February 28, 1975
    • 5138
    Re: can you identify this big tank?
    Joe--
    Not sure what you're looking for here--it's obviously a 24-gallon tank installed in either a red 56-60 (looks like 56-57 venetian red).
    I'm guessing that you are looking for greater specifics, like "whose legs are those, and what is the situation with this tank--going in or going out?" (But, as you noticed, that didn't stop me from adding my 2 cents.)
    Mike Ernst
    • Joseph T.
      • April 30, 1976
      • 2074
      Mike
      I have seen a few original big tanks but cannot claim any special knowledge. I remember seeing one that Dick Ferando sold to Dale Pearman that was similar to this one. It was Fiberglass..this one pictured is metal with some fiberglass sheathing around the mid circumfrance. The gas filler neck coming through the filler door I have seen once before years ago..but am not sure if this set up was factory or not.
      Looking to hear more from those that have had lets say 58 - 62 big tank cars and might be more familiar. with the over all look and hardware. The factory backed 56 57 big tank racers had center fill tanks..with the #3 and #4 57 Sebring cars being at least two exceptions..having been modified with right hand side fill big tanks for the Sebring pits.
      Joe
      • William C.
        • May 31, 1975
        • 6037
        Joe, I believe the center fill was used on the 36 Gal tanks which was an "over the counter" part rather than the RPO option of 24 which used the side fill. There are several good articles on these tanks in past issues of the "Corvette Restorer", including I believe one by Mike Ernst.
        Bill Clupper #618
        • Mike E.
          • February 28, 1975
          • 5138
          It is definitely configured like a factory 24-gallon tank. The vent pipe and stand on the top, etc., is identical to the fiberglass ones of 60-62. But this one is metal?
          I know that the 37-gallon solid axle tanks were fiberglass in 60-62, and in 56 were metal--I don't much know the history of the 24-gallon tank prior to 60.
          There are very few out there--I've only had two cars with them (and the Gulf car with the 37-gallon tank) in my 30+ years with solid axles. They're hard to find, and even harder to find are the low-horspower cars with them, although I have documented two 300-hp 62's with the fiberglass 24-gallon tank that were, to all intents and purposes, originally so-equipped.
          By the way, I know of one of those 300-hp cars bought in the mid-60's by the guy who still has it--it didn't have the tank when he got it, so a dozen years ago when he "restored" the car, he filled in the inner-body holes unique to the 24-gallon tank cars. To each his own!?
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            Say Mike, This does not address Joe's post...
            ...but, since you mentioned it, my Silver/Red 11966 '62 is a 24 gal tank, 300 hp, 4 speed, 3.08 posi, metallic brake, no radio freeway cruizer...
            • Joseph T.
              • April 30, 1976
              • 2074
              big tank filler neck
              Bill
              To qualify for Sebring March 56 an internal request was made for several performance and HD parts including a 37 1/2 gallon tank...resulting in a small number of them being made in metal with center fill configuration.
              This continued through Dec 1956 Nassau but was updated to a right hand fill for Sebring March 57..probably..still metal!
              The RPO 24 gallon tanks that I have seen that were used and were available over the counter were fiberglass.
              What is unique about these 2 big tanks in the Wisconsin collection is that they are what appears to be the same 24 gallon configuration..as the RPO tanks but these are metal!
              Joe
              If these are GM tanks..they would be very special.
              • Loren L.
                • April 30, 1976
                • 4104
                Yeah, a red circle with an "x" *NM*
                • Loren L.
                  • April 30, 1976
                  • 4104
                  According to Delmo Johnson, the RH
                  fill tanks were a modification by Dick Doane.
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    There's also a base motor PG '61 here in Phoenix, with the original owner now retired in Sun City - car was sold new in Texas........
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      Under this message, I can see the picture.
                      If this is for sale, I just talked to someone yesterday who wants to buy the setup pictured - his was modified to put a sprint car cap (normally in a center fill) into the gas cap area.
                      • Joseph T.
                        • April 30, 1976
                        • 2074
                        closer look at big tank top *NM*
                        • Joseph T.
                          • April 30, 1976
                          • 2074
                          another view of the tank
                          Loren..there are two of these big tanks in the 21 trailer load collection at De Pere Auto..as featured in Old Cars weekly.
                          I went up and reviewed the whole lot this past weekend.
                          It is all for sale as a total lot...cars and parts.
                          12/15/05 it turns into a Pumpkin or a dream come true for someone!
                          • Mike E.
                            • February 28, 1975
                            • 5138
                            Re: Say Mike, This does not address Joe's post...
                            Must be one of those "if you order the big tank you can't get a soft top or a radio" cars, huh?
                            • Mike E.
                              • February 28, 1975
                              • 5138
                              Do the extra two tailllights come as part of the big tank package too?
