69 rim date code - NCRS Discussion Boards
69 rim date code
  • Greg L.
    • March 1, 2006
    • 2291
    69 rim date code
    I'm looking at buying a rim and the code on it is as follows
    K18 12 (valve stem) AZ
    I read it as a Dec/68 manufacture date but find it odd that there is nothing stating the day of the month as per the TIM&JG. Any thoughts on this one? Thanks.
  • Mark #28455
    Re: 69 rim date code
    Sometimes the date code is missing a digit or 2 - may have been over the valve stem hole or been missed. The date code may also be 1978, there was an article in the Restorer about date codes maybe a year or 2 ago that explains what else to look for.
    Mark
    • Harmon C.
      • August 31, 1994
      • 3228
      Greg
      You should find a number between the valve stem and the AZ this will be the day of the month it is sometimes very light. As for 68 or 78 as I recall 68 may have a round dot of like weld on the outer edge of the front side but I am not sure.
      Lyle
      Lyle
