396 side-flags (cast numbers on backside) - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    I've always been curious why all the fender emblems that I have seen have both the 396 part numbers AND the 427 - 1966 part numbers cast on the back. Example of this set on eBay (link below).
    Did the earlier 396's have only their proper number ? And are all others GM service parts for 1965 ?
    396 side flags
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 396 side-flags (cast numbers on backside)
    Wayne - According to the 396 gurus, 1965 396 side-flags only have the 1965 number. The 1966 version has the two numbers. Pete
    • Bill W.
      • March 1, 1980
      • 2000
      I have the original off 65# 17346 and it has no part #s .It appears to be made by bSc or bSg company.The later emblems with two part #s are made by General out of Detroit.Also on the original there is much less brushing on the turbo jet portion & the lower stud was made about 3/16 shorter than the replacement emblem ,and was not cut off....Bill
