D-112P ignition points distinguishing features - NCRS Discussion Boards
+ More Options
Posts
  • mike cobine
    Can anyone tell me specifics on the D-112P points as to differences you can see to identify them?
    The pictures I have posted below seem to indicate that the D-112P has a solid pivot post while the D-106PS does not. However, checking the D-106P set I have also has a solid pivot post. The wiring attachment seems to be the same as the D-106P (not pictured).
    Are there any numbers or marks that distinguish the D-106P from the D-112P when you are looking at them?
    I have several distributors with points that I would like to identify and I believe some are the D-112P as I usually bought the high performance points.
    D-112P and D-106PS
  • Mike McKown
    If you have several of each it's easy to tell the
    difference just by taking your finger and triggering the points. There is a DEFINITE difference in spring tension. Otherwise, if you don't get a solid answer, I can look at the new set I have and tell you the difference.
