'66 REAR SPINDLE REMOVAL - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I recently had the right, rear wheel bearing replaced. The rotor on that side has had the rivets removed. I was thinking of removing the spindle from the trailing arm to have the rotor rivetted to the hub as original, which I should have done while it was out. I have the rivets and I know a guy that has a press setup to put them on correctly. How difficult is it to remove it now, and do I need the spindle knock out tool I see advertised to remove it, even though it is freshly installed?
  • Norris W.
    • December 1, 1982
    • 684
    Re: '66 REAR SPINDLE REMOVAL
    Yes, you need the press out tool. It's a press fit, freshly installed or not.
      • 43236
      Rob-----
      To be honest, I would not recommend "messing with the rivet installation" at this point.
      • William V.
        • December 1, 1988
        • 399
        Rob
        I suggest that "if it ain't broke don't try to fix it". You could easly damage the new bearing during removal.
        BV
        • Rob A.
          • December 1, 1991
          • 2126
          I THINK I WILL JUST LEAVE IT...THANKS... *NM*
