3814 holley - NCRS Discussion Boards
3814 holley
  • Dale S.
    • November 12, 2007
    • 1224
    3814 holley
    Help please, what is the date of a service replacement carb List 3814 date 2285? thank you Dale
    • 43222
    Re: 3814 holley
    dale----
    It's the 228th day of 1975, 1985, or 1995. I don't know, at the moment, exactly when that carb went out of production, so some of those years might not be possibilities.
    • Dale S.
      • November 12, 2007
      • 1224
      Re: 3814 holley
      Thank you Joe, It just went off and had one of those hidden bidder things. I guess it is better than the 3810, I have on my K-19 car. There is also a July of 1966, 3814 on ebay, would that be better than the service relacement 2285? thank you for all your help Joe. Jerry F. do you have any comment on this?
      • Gerard F.
        • June 30, 2004
        • 3806
        Re: 3814 holley
        Dale,
        I saw that 2285 on ebay and was going to let you know, but it needed an overhaul and it had something wrong with the fuel bowl. I'll look up that July 66 one and let you know.
        Jerry Fuccillo
        #42179
        Jerry Fuccillo
        • Gerard F.
          • June 30, 2004
          • 3806
          Re: 3814 holley
          Dale,
          Looked up that 673. Looks good to me, but it will need a complete restoration job if you want show it, about $300 worth. A lot less just to rebuild. Looks like it has all the parts, maybe one screw missing in the vacuum secondary.
          If it's within 6 months of your car it would be perfect. Anyway the original 3814's don't come up too often, not as often as the 3810's, so you might not care about the 6 month envelope.
          I have dealt with the seller before, and I think he is a straight shooter. I have bought a number of holley parts from him. He is a rebuilder and can probably rebuild it for you.
          The only difference between a 3810 and a 3814 is the throttle plate assembly (larger vacuum port) and the primary metering block. All the other parts are identical and interchangeable.
          I'll keep an eye on it, and email you.
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
          • Dale S.
            • November 12, 2007
            • 1224
            Re: 3814 holley
            Thanks Jerry, you help is greatly appreciated. Dale
            • Gerard F.
              • June 30, 2004
              • 3806
              Re: 3814 holley
              Dale,
              It's up to $85 with 2 bidders, it might just go at a reasonable price early this evening. Did you get my email?
              Jerry Fuccillo
              Jerry Fuccillo
