Are these correct parts for a 1967 427 with A/C fan shroud?? 3935571, 3935572, and 3888268. Thanks Larry
1967 fan shroud part numbers
Re: 1967 fan shroud part numbers
Larry -
The A.I.M. shows 3888269 (upper), 3911110 (RH) and 3886887 (LH), and C60 adds the 3887428 extension ring. Those are the original production part numbers - they may have been superceded later by others.- Top
Larry------
The GM #3935571 and 395572 are part numbers for components of the 1968 radiator shroud assembly used for 1968 big blocks (except L-88) and some 1968 small blocks. These components were never used for any 1967 radiator shroud assembly. The GM #3888268 was a component used for 1967 SMALL BLOCK shroud assemblies.
The ORIGINAL 1966-67 big block shrouds were never available from GM as an assembly. They were available only as component pieces. The 1968 shroud was never available in SERVICE as component pieces. It was available only as a complete assembly under GM #3938940. This shroud was the SERVICE shroud assembly for 1968 applications with copper/brass radiator. It later became the SERVICE shroud assembly for 1966-67 Corvettes with big block (except L-88) when the component pieces of those shrouds were discontinued from SERVICE.
A shroud containing the 3 pieces that you mentioned is very likely the GM #3938940 SERVICE shroud assembly. It was GM-discontinued several years ago.In Appreciation of John Hinckley- Top
