1954 fuel pumps - NCRS Discussion Boards
1954 fuel pumps
  • Mark M.
    • December 1, 2004
    • 2
    1954 fuel pumps
    I am working on replacing the fuel pump on a late year '54 vette. My question is,
    what is the difference between the 9797 and the 4132. I do not want to install
    the wrong pump.
  • John S.
    • July 31, 1990
    • 292
    Re: 1954 fuel pumps
    Not positive but I think the out lets are just a little bit different in postion and not in thread size. john
    • Chuck G.
      • May 31, 1982
      • 2034
      Re: 1954 fuel pumps
      The only difference is that the "top half" of the 4132 is rotated about 20 degrees outward in relation to the 9797, so that the fuel outlet is parallel to the engine block. You can take a 9797, unscrew the top, rotate and retap some holes, and you'll have the 4132 configuration.
      Unless you have a VERY early 54, you need the 4132 configuration. Chuck
