More 62 Wheel Woes - NCRS Discussion Boards
More 62 Wheel Woes
  • Richard T.
    • February 1, 1979
    • 858
    Re: More 62 Wheel informatiom needed (Dale)
    Deb, Yes you are in the right area , you only need to remove the tire (or at least deflate it and brake the bead ) to check the date. Rich
    • Deb
      Re: More 62 Wheel Woes ( thanks to all)
      To dale, I could use three more like the two welded ones I have. The other two I have on the car are riveted, one with the four lugs and one without (hard to keep the wheel cover on this wheel).
      To everyone who helped out thank you so much, the information is invaluable, knowledge is priceless. I know I must have tried everyones patience at times but I sure do appreciate everyone hanging in there.
      Thank again,
      Deb
      • Richard T.
        • February 1, 1979
        • 858
        #18
        Deb, With patience you can find these wheels at swap meets but it gets tougher every day. Now that you know what your looking for you won't run the risk of passing up any correct ones. Good Luck ! Rich #2276
