427 TIMING SPECS - NCRS Discussion Boards
427 TIMING SPECS
  • Howard K.
    • November 11, 2011
    • 111
    427 TIMING SPECS
    Can anyone help me with the timing specs and rpm settings with my 67 427-400hp 4SP with ac and smog. Thanks in advance.
    • 43221
    Re: 427 TIMING SPECS
    glen-----
    Initial timing= 4 degrees BTDC
    Idle speed= 750 RPM (with A/C "on")
    • Howard K.
      • November 11, 2011
      • 111
      BACK TO JOE
      Is there no difference with smog pump. And what would it be with ac off
        Re: BACK TO JOE
        Glen -
        Joe gave you the setting for smog (non-A.I.R. 400's were set at 550 rpm). There is no printed spec for idle setting with the A/C off - set it where you like it and it doesn't get rough when you turn the A/C on.
