Part # 1052271 Rear Axle Lubricant - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Is this GM Axle Lubricant approved for my 68 Positraction rear end or is it for regular GM rearends only?
    I don't want to do any damage or cause any problems.
    Thank you,
    Kurt #26406
    • 15674
    Re: Part # 1052271 Rear Axle Lubricant
    1052271 is okay for all vintage Corvette axles (and manual transmissions) and so is any commercially available SAE 80W-90 GL-5 gear oil, which will probably be cheaper.
    If the axle is Positraction you must add at least one 4-oz. bottle of 1052358 friction modifier additive (or equivalent) to prevent Positraction clutch chatter.
    IIRC the capacity of the Corvette axle is speced at 3.7 pints.
    • Kurt B.
      • July 31, 1996
      • 971
      Thank you Duke *NM*
        • 43221
        Kurt-----
        GM #1052271 is GM-discontinued. It's replaced by GM #89021671. That's what I recommend you use.
        • Ken A.
          • September 30, 2002
          • 167
          My rear end guy recommends the posi fluid from Ford. Says it's better & cheaper than GM. Also, I don't know the part numbers, but the last time I tried to buy the GM posi fluid (2 years ago), it was no longer available in Calif.
          Ken
            • 15674
            AFAIK the Ford and GM addtive is the same along with other OEMs.
            Any clutch or cone type LSD needs the same addtive.
