TRIPOWER HEADACHES - NCRS Discussion Boards
TRIPOWER HEADACHES
  • Howard K.
    • November 11, 2011
    • 111
    TRIPOWER HEADACHES
    Iam attempting to line out a recent 67 tripower startup and am having a few problems.I was wondering since i do have the smog option if that effects the timing spec of 4 degrees BTDC. It also has AC. The car starts fine but does not want to shut off immediately. I also noticed a tremendous amount of vacuum at the front carb and hardly any at the middle carb effecting the vac advance.
    Any help greatly appreciated.
  • Daniel S.
    • February 1, 2000
    • 164
    Re: TRIPOWER HEADACHES
    If your experiencing 'run-on', this could be caused by too high of an idle speed.
    • Clem Z.
      • January 1, 2006
      • 9427
      the center carb may have "ported vacuum" where you see little or no vacuum till you "crack" the throttle and the port on the end carb is seeing manifold vacuum. try disconecting all the linkage from all carbs and make sure all the butterflys are closing all the way
      • Howard K.
        • November 11, 2011
        • 111
        Thanks Clem
