C2 question, maybe stupid. - NCRS Discussion Boards
  • Joseph R.
    • 94
    Regarding C2's, if one has the body stripped of exterior panels, is there any difference between a convertible and a coupe body structure (from the firewall back & excluding doors and birdcage)????
    Thanks, Joseph Rock
  • Mike M.
    • May 31, 1974
    • 8389
    Re: C2 question, maybe stupid.
    rear surrounds differ. mike
    • mike cobine
      So do the rear bulkhead panels. One curves to fit the fastback, the other to fit the flat deck.
      • mike cobine
        Maybe a better question is what do you want
        to do with it? Are you making a convertible out of a coupe, a coupe out of a convertible, repairing one with the other, or building a Grand Sport kit?
        • Joseph R.
          • 94
          Re: Maybe a better question is what do you want
          Looking at the potential of a convertible, devoid of exterior panels to build a Grand Sport Prototype coupe. The plan is for fixed headlights, slightly widened fenders, GT "trunklid", etc.
          • mike cobine
            You will need the upper birdcage and I think the front at the windshield is slightly different. I think the birdcage uprights at the back of the doors are different at the top of the fender in the convertible and the coupe, but I doubt it is much.
            Not that it will matter that much, since if you are fabricating a body, you can easily fabricate a few changes in the birdcage.
            You will have items like the deck hinges and the convertible top mounting plates that are unnecessary.
            • Wayne W.
              • April 30, 1982
              • 3605
              The floor (tub) is the same. There is an extension for the coupe rear roof line. The fenders are the same. The front is the same.
