1967 HP engine code..... - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    When checking out a 67 with a 300hp motor and A/C, I noticed a HP engine code According to the books the HP is for 350hp+A/C. Note, the block pad looks legit with the appropriate vin stamp, casting date, and casting number. Is this a factory anomaly or just a mutant? I suppose anything is possible...
    • 43221
    Re: 1967 HP engine code.....
    Jim-----
    It's possible that it's a factory-incorrect stamping. However, are you sure that the engine is not an L-79? Some peripheral items could have been changed along the way such that it's currently "disguised". What is the tach redline in the car?
    • Kevin M.
      • November 1, 2000
      • 1271
      Maybe it was HR, my 300 327 PG A.I.R has a HR stamp. Did you mean AC or A.I.R? if A.I.R it's HR.
      Kevin
      • Jim V.
        • November 1, 1991
        • 587
        300hp tach...redline 5500..correct 300hp intake, carb, valve covers....etc
        • Jim V.
          • November 1, 1991
          • 587
          Understand...but it is A/C not AIR....strange...
          • Gerard F.
            • June 30, 2004
            • 3806
            Joe,
            Did they produce any base engines with A/C? If so, what would be the engine code, would it still be HE?
            Jerry Fuccillo
            Jerry Fuccillo
              • 43221
              Jerry----
              Likely, there were more base engines manufactured with C-60 than any others. The codes were the same as the non-AC codes for the particular transmission and K-19/non K-19 application.
              I don't know why the L-79 had a special code for those with C-60. There must have been some engine plant-installed component of the engine that was specific to C-60 applications, but only for L-79 and not the base engine. I don't know what it was, though.
              • Kevin M.
                • November 1, 2000
                • 1271
                Got home and Nolands book pg442 reads "HP base or L79, 300hp or 350hp with C60 and N40" Sounds like your engine.
                Kevin
                • Mark #28455
                  was it a different exhaust manifold? *NM*
                  • Kevin M.
                    • November 1, 2000
                    • 1271
                    A/C with Power Steering 300 & 350 HP *NM*
                      • 43221
                      Re: was it a different exhaust manifold?
                      Mark----
                      Exhaust manifolds were the same for all 67 small blocks. There was a difference, of course, between AIR and non-AIR engines with respect to exhaust manifolds and other engine plant-installed components (and, different suffix codes for these). There was no other difference for 67 small blocks, though.
