69 exhaust recommendation please - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Could someone recommend an exhaust supplier that would comply the most with the judging sheets for a 69? I've decided not to go with stainless and to go with the welded type(muffler welded to the aft pipe). This leaves me with the welded type of alluminized or carbon steel material. I believe carbon steel would be original but I don't know if anyone makes it this way. If alluminized is the way to go then what kind of a point deduct should I expect? Your suggestions are appreciated as I am trying for the least amount of points deductioned.
  • Kenneth G.
    • March 1, 1999
    • 136
    Re: 69 exhaust recommendation please
    greg,
    i have aluminized on my 69 but dont know where it is from as my resto shop ordered and imstalled it. its held up quite well with no rust (a little rust on the seams of the muffler but thats it)
    kenny #31871
    • Wayne P.
      • August 31, 1975
      • 1025
      Try Jack Horner at East Tennessee Corvette. His products are sold by Volunteer Vette. Both are located in Knoxville,TN.
      • Kent K.
        • December 1, 1982
        • 1139
        Greg---
        If memory serves me correctly, about 12 years ago, I ordered a set of exaust pipes and mufflers for my '67 from Allen's and requested they use carbon steel instead of aluminized or stainless. I had to request the additional shipping charge for their over sized length since I wanted them exactly like originally installed during assembly. They judged very well. Just a thought for your '69.
        Kent #6201
        Kent
        NCM Founder - Member #718
          The deduction for aluminized is so tiny, I wouldn't even think about using a carbon steel system that will rust almost instantly; but, that's just me
            • 11643
            50% point loss on originality for an aluminized system. But, I think it will last a LONG time, and my 72 still got a Top Flight.
            Patrick
            • Harmon C.
              • August 31, 1994
              • 3228
              I would think aluminized would be 20%. Other things not correct could get you to 50%. Lyle
              Lyle
              • Mark #28455
                you'll also lose points for the bends being wrong *NM*
                • Greg L.
                  • March 1, 2006
                  • 2291
                  Re: you'll also lose points for the bends being wr
                  Thanks guys. I guess if the point deduct is small then I'll go with the alluminized ones....now....2" or 2 1/2"???
                  • Warren F.
                    • December 1, 1987
                    • 1516
                    Greg:
                    Only 2" used in model year 1969, for all applications.
