1960 Dual 4bbl Carb Jets - NCRS Discussion Boards
  • Bob Babcock
    Can anyone tell me what the proper jet sizes would be for a 1960 245hp dual 4bbl carbs set-up would be??? Just finishing a restoration. Thanks! Bob
    • 43232
    Re: 1960 Dual 4bbl Carb Jets
    Bob----
    According to my references both carburetors originally used the same jets. These are as follows:
    primary-----Carter #120-166------GM #1459366
    secondary---Carter #120-217------GM #3744038
    With respect to the GM part system, these pieces are long-since discontinued. However, I wouldn't think that they'd be too difficult to otherwise obtain, perhaps through the Carter (Federal-Mogul) parts system or other aftermarket carburetor parts supplier. Using either the GM or Carter numbers they ought to be easily cross-referenced.
    • motorman
      pri .093 sec .053
      • Doug Flaten
        When I contacted them last year, Federal Mogul / Carter told me that they had sold all of the old carburetor parts, rights(?) to another company. I think it was Daytona Carburetor in Florida.
        • James F.
          • December 1, 1985
          • 596
          Bob, You might have better luck looking for Carter AFB jets in the size you need, they will fit the WCFB's. Regards,
          • motorman
            jim did that fix on the fuel pump valves you Emailed me about work?
