After having my rear wheel bearings replaced and wheel assemblies reinstalled my rear end sits peculiarly high with the wheels tilted too far in at the bottoms. Also the rear sway bar now rubs against the inner part of the tire. By looking it gives the appearance that the axle shafts are too short and pulling the wheels in. Prior to the new bearing and spindle installation the old spindles where floating.
Is it possible that by having them floating the previous owner averted this problem, and now that I've gone back to the original, pressed spindles there isn't enough length somewhere in the trane? Is it possible that when the rebuild shop was pressing the bearings they miscalculated something so severely that this could happen? (Vansteel in Clearwater FL. A reputable shop as far as I know.)
Any insight would be great. Thanks.
