63 gauge connection / wiring harness - NCRS Discussion Boards
  • David Z.
    • February 1, 2004
    • 21
    I'm restoring a 63 to sportsman standards. The car came with a newly restored 63 gauge housing and gauges but the gauges, tach and speedometer are 65-67 type. Will a 63 wiring harness connect to the 65-67 gauges correctly? I ask this question to Lectriclimited but could not get this question answered. Also what is a good reference for installing the wiring harness? Thanks for your help.
  • William C.
    • May 31, 1975
    • 6037
    Re: 63 gauge connection / wiring harness
    Yes, I believe the connections are the same. The Assembly Manual is about as good as it gets for installation instruction.
    Bill Clupper #618
    • Bob R.
      • June 30, 2002
      • 1595
      Just curious, but the 63 gauge cluster has a shorter cutout for the steering colum. The column in a 63 sits lower then the 64 - 67. Is your column at the correct height for a 63? If it is the housing is a 63 if not the housing is from a later year. I agree the connections should be the same.
      • David Z.
        • February 1, 2004
        • 21
        The gauge housing and colunm is a 63.
