61 Horn Mount Location - NCRS Discussion Boards
  • Paul M.
    Infrequent User
    • November 1, 2005
    • 15
    Where are the horns mounted on 61 cars please?
    We have a car with no holes for the horn brackets.
    Thank you, PM
  • Rob Edwards
    Re: 61 Horn Mount Location
    Here are two shots of our '62, the picture is the passenger side 442. The link shows the driver's side, which is from further away and shows a hole whre the mounting plate (and horn) should be (working on it!) Let me know if the pictures/orientation aren't clear, or if you need measurements from nearby landmarks.
    • Dennis A.
      • April 30, 1999
      • 1010
      Paul...
      From inside the wheel wells, look or feel upwards near the front, you may still locate were the horn mount nut plates were riveted.
