69 corvette interior - NCRS Discussion Boards
  • Frank & Paula Lowery
    We will be restoring the interior of our 69 this winter. This includes
    repairing/redying dash pads, door panels, etc. Replacing carpet, duct work
    seals and heater core while everything is out. Also refacing guages. In case
    we run into a problem, which is probably guaranteed. Does anyone know of an
    interior specialist familiar with the unique interior of a 69, i.e. vacuum
    hook-ups, electrical connections, etc. in the Oxford/Anniston Alabama area?
    This is between Birmingham and Atlanta. Thanks in advance for any help.
  • Terry F.
    • September 30, 1992
    • 2061
    Re: 69 corvette interior
    Make sure you have an assembly manual, take notes and pictures. It is not too bad if it is a non-air car. Terry
    • Klaus Friedrich #33362
      Hi Frank, hi Paula,
      I've done this work last winter. The goal was to change the wire harness that was really bad.
      First advice: buy a digital camera and take as much pictures as possible. The more the better.
      Second: Be aware of the sockets for the instrument blubs. They fell apart when you even look at them. I have to mount and dismount the left dashbord six times until they all fit.
      Third: I had to replace the upper dash. The reproduction fits perfect, but there is one bolt behind the left dash that doesn't fit. I cut it off.
      Fourth: Check your wire harness! The insulation off the wires must be perfect. If not change the wire harness. You'll never do it again when the car is assembled again.
      Fifth: Don't think of two or three weeks of work - think in months.
      I hope it helps
      Germany
