C2 Undercoating Remover - NCRS Discussion Boards
  • Tony C.
    • February 29, 2008
    • 117
    Hi
    I have to remove some undercoating that was sprayed on the under side of the fiberglass body. What can I use to remove it?
    Thanks Tony
  • Joe R.
    • March 1, 2002
    • 1356
    Re: C2 Undercoating Remover
    Hi Tony:
    I had the same problem. In my case I was able to soften the undercoating with mineral spirits, which is a mild petroleum distallate often sold as paint thinner for oil based paints. Just make sure the label says the contents are "mineral spirits."
    What worked best for me was to simply brush it on and let it soak into the undercoat for a while. Then I could scrub it off using a rag or one of those scrubbing pads that I think are used for removing paint. It was tempting to use a putty knife, but I found that doing so tended to leave scratches in the fiberglass finish. I did make some use of a plastic scraper that is sold for use with paint remover.
    For me, the key element was patience. The mineral spirits did soften and dissolve the undercoat, but it worked slowly. The nice thing was that the end result looked great, with no damage to the fiberglass. I even found the body job number in yellow marker under the undercoat on the passenger footwell.
    There may be some other solvents that work better, so you may want to experiment with a few before you tackle the whole job.
    • Dave S.
      • August 31, 1992
      • 2926
      Tony,
      Kerosene is worth a try as well. Undercoating varies. I did a 72 that was fully covered and found the kerosene to work best. Joe's right on with patience and possibly a plastic scraper. Don't forget latex gloves, rags etc. Good Luck
      • Rick S.
        • January 1, 2003
        • 1203
        I started with a propane torch to warm things up prior to scraping and that helped to remove the majority of the undercoating. As Joe and Steve said, be patient, it took me 3 months a few winters ago and I thought I wore out my right shoulder socket. It's amazing how many nooks and crannies are on the bottom-side of a car!!!
        • Alan Drake
          I use Brake Cleaner. It removes it with just a spray and its relatively cheep. Remember to vent the area.
          • Floyd #21606
            I agree with Alan, I use brake cleaner too and it is not as labor intensive as scraping the old undercoating off.
            Floyd,
            65 Fuelie
            • Jon S.
              • November 1, 1992
              • 202
              Floyd or Alan, the brake cleaner didn't harm the glass? Thanks jon
              • Floyd #21606
                Jon, I didn't have any fiberglass problems while removing the
                undercoating from my vette using brake cleaner. I wouldn't leave
                it on and walk away. I put news paper and a pan under the area
                that I was spraying and I would wipe off the undercoating with
                paper towels and spray again until I removed all the undercoating.
                Hope this helps
                Floyd,
                65 Fuelie
                • Jon S.
                  • November 1, 1992
                  • 202
                  Floyd, did you do a final wipe down with anything after you had the under coat removed from a given area? Thanks! Jon
                  • Floyd #21606
                    Joh, I just wiped the area with water on a damp cloth.
                    • Jon S.
                      • November 1, 1992
                      • 202
                      Thanks Floyd-I'll give er a try! *NM*
