Acv 306 vs 307 Radiator cap - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2925
    All 306 radiator caps I have seen are aluminum. Sometime in mid production 1961 the caps were changed to 307 and that cap was used into 1964. I have what appears to be an original 307 that is made from steel. Was the 306 the last of the aluminum caps and were all 307's made from steel.???? The 61/62 Judging Guide is silient on this. Any help is appreciated.
  • Mike E.
    • February 28, 1975
    • 5139
    Re: Acv 306 vs 307 Radiator cap
    That's exactly what I've seen, Dave. And the 306 had more of a yellow/green hut to it, even though it was aluminum. I haven't quite figured that one out, but I'm not a metallurgist.
    • Dave S.
      • August 31, 1992
      • 2925
      Mike,
      Thank you. It seemed funny to me that the 61/62 TIM & JG didn't mention this change as it occurred during 61 production.
      • Christopher R.
        • March 31, 1975
        • 1599
        Not sure, but I thought the 307s were stainless steel. I thought the change was made by Chevrolet because of electrolysis concerns with a steel cap and an aluminum radiator.
        • Dave S.
          • August 31, 1992
          • 2925
          Chris,
          My 307 holds a magnet so on that basis I assume its steel.
          • Peter L.
            • May 31, 1983
            • 1930
            Dave/Chris - The original 307 radiator caps were zinc plated steel. The large washer directly under the cap was aluminum and then there was a large fiber washer. The rivet was also aluminum. Other radiator cap assemblies like the RC-15 and the RC-26 came out initially as zinc plated steel and then in the late 70s or 80s these radiator cap assemblies came with a stainless steel cap; but I do not recall seeing a version of the 307 with a stainless steel cap. Pete
              • 43229
              Pete-----
              There was never a version of the '307' with a stainless steel shell. The '307', a 13 psi cap, was discontinued and replaced by the 15 psi RC-26 in April, 1974. This was well before the advent of the stainless steel shell caps. Consequently, there never was a stainless shell version of the '307'.
                • 11647
                Joe,
                The RC-33 came out in 1973 with a stainless steel shell. So, April 1974 is not prior to the advent of that form of cap. But, I highly doubt they changed the 307 to stainless.
                Patrick
