Anyone have haz warning option on their '66? - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I have a question about the hazard warning flasher option on a '66 if anyone out there has it installed on their car....
  • frank clark
    Re: Anyone have haz warning option on their '66?
    I have it on mine. I will try to help.
    frank
    • Jerry M.
      • March 1, 1980
      • 61
      I also have it on my car. I'll help if I can.
      Jerry
      • Gary #41345
        Question is?
        • Rob A.
          • December 1, 1991
          • 2126
          Thanks Frank...
          Does your wiring harness have 2 black, single row connectors, and one double row, or 2 double row?
          The orange wire that goes to the fuse box to the BATT slot has a second wire coming out of its' connector. How long is that unused wire and what type of connector is on the end?
          Is the nut that goes on the outside of the parking brake handle bracket to hold the switch the thin, round type with ridges on the edge? I'm can't find that type anywhere...so far.
          • John L.
            • 409
            Rob see my responses interspersed below
            Does your wiring harness have 2 black, single row connectors, and one double row, or 2 double row? - It has two single row and one double row
            The orange wire that goes to the fuse box to the BATT slot has a second wire coming out of its' connector. How long is that unused wire and what type of connector is on the end? - that wire is 1.25 inches
            Is the nut that goes on the outside of the parking brake handle bracket to hold the switch the thin, round type with ridges on the edge? I'm can't find that type anywhere...so far. - Yes it is.
            • Rob A.
              • December 1, 1991
              • 2126
              Thanks for the response John. Does the 1.25 inch wire have the same connector, if any, as the one that plugs into the BATT slot? It looks different in the assembly manual drawing...
              • John L.
                • 409
                Rob - the connector attached to the irange tail wire is somewhere between 25% and 50% larger than the one that plugs into the battery slot. The orange wire going into it is exactly the same size as the other. I do not see any numbers on the connector.
                • Rob A.
                  • December 1, 1991
                  • 2126
                  Thanks again John...one more question...is it the same type, but larger? I have an old, original wiring harness that I use for connectors, maybe I can find one on it. Thanks Again...
                  • John L.
                    • 409
                    Rob -- no problem -- Yep -- It is the same type --- single spade -- only larger. I dont have a digital camera or I would post/send a picture.
                    • Kent D.
                      • February 1, 1992
                      • 100
                      My short orange wire dose NOT have thae same connecter as the one that plugs into the batt. slot. It is the same as the tab in the fuse box so that you can plug another assery wire into it.
                      • John L.
                        • 409
                        Oops - I apologize for goofing this one up. Although the tail connector is similar and certainly larger it is not identical to the other connector. The tail connector as I said is a single spade connector (male) The other connector which plugs into the Bat slot would be considered a "female". The spade on the tail connector is in fact made so that you could plug another female type connector into it. Sorry for any inconvenience. Looks like I better adjust my presciption. Kent thanks for catching this.
