C2 Differential Mount Bushing - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    I changed body mounts and now the Differental yoke hits the tunnel under light power load so I assume the bushing under the drive shaft is shot although it looks fair. Do I need to lower the hole diff assemblt to change it? I can't get the bolts out as they hit the body before they come out. Can I pry the mount down & slip the new bushing in?
    Thanks for any help!
    Brian
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
  • Rob A.
    • December 1, 1991
    • 2126
    Re: C2 Differential Mount Bushing
    I'm not sure what's causing your interference, but you can change the differential mount to frame rubber mounts without removing the driveshaft or lowering the differential. I recently replaced the rubber mounts on my car, and the bolt can be removed with the driveshaft in place.
