I have been chasing a rough idle problem in my 67 327/300 ever since I bought the car last year. I have methodically worked through the fuel and ignition systems (which needed attention anyway for Flight judging) but this has had no effect on the idle problem. Currently I am looking more carefully at ignition timing.
The engine idles reasonably well in neutral at 800 RPM, although I think it is a bit more lumpy than some other 327/300 engines I have listened to. However, I don't think I would consider the idle quality a problem if I had a manual transmission.
My problem manifests itself mostly because I have a Powerglide transmission. If I set the idle speed to 700-800 RPM in neutral, the engine will stumble and stall when I put it into drive. To keep the engine from stalling when I put it in drive, I have to set the idle speed to 900 RPM in neutral. In drive, the idle speed drops to about 600 RPM and the idle quality is poor.
Vacuum tests show that the idle vacuum is about 17 inches at 900 RPM in neutral, but vacuum drops to 9 inches at 600 RPM in drive. Timing tests indicate that the total advance at 900 RPM in neutral is 20+ degrees, but it drops to 6 degrees (the setting for initial timing) in drive. In other words, the vacuum advance drops out completely when I put the car in drive at idle.
I think I may have a chicken-or-the-egg problem here, since low vacuum causes the vacuum advance to drop out, and the loss of the vacuum advance causes low vacuum.
The factory specs for my vacuum can specify 0 degrees at 6 inches and 15 degrees at 12 inches. Bench tests on the actual can that I have show that it begins to move at 7 inches and is all in at 16 inches. So, it may be slightly out of spec but not a lot.
Anyway, some simple experiments with higher initial advance show a noticeable improvement in the problem. This suggests to me that I might want to switch to a vacuum can that provides full vacuum advance at vacuum of 9 inches, so that I get full vacuum advance even at 600 RPM in drive.
My apologies for the long description of the problem, but this leads me to a couple questions that I hope other board members can help me with:
1) In a stock 327/300 with Powerglide, what should the vacuum level be at idle with the transmission in drive? If someone out there has a similar car that runs well, I would appreciate hearing the results of an actual test.
2) If normal idle vacuum in drive really is in the 9-10 inches range, would it be okay to switch to a vacuum can like the L79 version, which is all in at 7 inches? Is there any risk of damage to my engine if I make this change?
Thanks in advance for any insight that you folks can provide.
