My '72's floor-to-firewall seam is seperated on the driver's side. I plan to repair with Fusor epoxy. My concern is that the reading I've done, related to adhesive repairs on fiberglass, says to grind away all remaining old adhesive before applying new. The trouble is, this seam is formed by the two panels overlapping, such that I cannot get in there to grind.
If I simply squirt some epoxy in the seam and hope for the best, is it going to come loose easily in the future? Any advice for a sound repair? Will the epoxy be happy in there with old, factory glue, or would I be better off using polyester, factory-type adhesive?
Thank you,
Patricia Brown
Thank you,
Patricia Brown
