Cylinder heads - NCRS Discussion Boards
Cylinder heads
  • GL Anderson
    Cylinder heads
    We all know how the broach marks on the cylinder block are supposed to look, but what about cylinder heads. I have a set of heads that appear to have the same type marks on their underside surfaces. Were heads done the same as the blocks?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Cylinder heads
    from the factory,yes they were done the same way
    • GL Anderson
      Re: Cylinder heads
      Thanks Clem!
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Cylinder heads
        i bet if you find a real sharp machinist he could take a part of a head and install it on the stamp pad area of the block.
