HELLO, I'm recorrecting the message that I had posted. I have a 72 vette coupe,it is a late build June 28th, S/N 1Z37K2S525020,it has Power Brakes. The NCRS Judge manual reads that the master cylinder should read: delco logo 5480346. I ordered a master cylinder from Chicago Corvette Supply and when I recieved it, it had the delco logo but no.3s read 5460346. I returned it back and they said they search more info on it. I'm suppose to call them back to let them know if I want it back. I want the correct no.#, where can i get a master cylinder with correct markings info ? Anyone that can help me solve this situation .please contact me, email me ccdm2p@msn.com or even call 480-720-0684 my cell.
RE: C3-72 Need Master Cylinder Message Recorrected
Tags: None
Re: RE: C3-72 Need Master Cylinder Message Recorre
Charles-----
There never was a casting or any other part of GM #5480346. So, if you have a master cylinder of that casting number, then it's "one-of-a-kind". That would make it very valuable, but only to the person that needs one. There are none of those people, so you'll never get much for it.
I'll bet that the casting number is actually 5460346. A stamped "PG" on the semi-circular machined front surface of the master cylinder will confirm that.In Appreciation of John Hinckley- Top
