Out for a cruise with the Vettes yesterday and discovered a --- what we believed lifter clicking as the engine was under load (not consistant)
Wooden stick to the ear technique found out the noise to be coming from the fuel pump (when the engine was reved up to the point where the noise was audible the wooden stick confirmed it)
Question : Is this the fuel pump rod that is worn or the fuel pump (possible the spring on the arm is broken) Do I replace both --- compare a new rod with the old one?
The Vette is a 1966 350 H.P. small block.
Bill
Bill
