1963 Rear Spring Plate - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    Are there any differences between the later 7/16" hole spring plate and one used for a 1963 9/16" hole other than the bolthole size?
    Thanks Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    • 43221
    Re: 1963 Rear Spring Plate
    Ray-----
    No, the hole size is the only difference. The 7/16" hole size plate, GM #457977, remains available from GM. The earlier plate is GM-discontinued. However, it's available in reproduction. Also, Vette Brakes sells a reproduction of the earlier plate which is thicker and, consequently, stronger. The original thickness plate is adequate, but I like the idea of the thicker plate. The "ears" of the stock plate can distort a little. This doesn't really cause a functional problem, but I don't like it.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks! Joe
      Ray
      Ray Carney
