1974 350 L48. I am preparing to replace the 2 gaskets at the fuel pump mounting.
I started to do this last night and ended up with trickling fuel from the pump to carb line for about a 1/2 hour. At this point I realized it was late and I needed more info.
To remove the pump enough to change gaskets, should I disconnect all 3 lines from the pump? If so, how much fuel can I expect to have leak out? The contents of the pump? The contents of the fuel tank? I hope not. Is there some thing I should plug before doing this?
One thing I didn't like was that leaking fuel got all down inside a steering rod end.
I'd appreciate any advice.
Todd
Todd
