What is the difference between an L71 - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    and an L88, other then cost these days?
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • mike cobine
    Re: What is the difference between an L71
    A lot. The L71 is the 435 hp, iron head, tri power 11:1 compression engine.
    The L88 is the 430 hp, aluminum head, high rise, Holley, 12.5:1 compression engine.
    The first made about about 450 or so real horses with open headers. The second made about 550 or more real hp with open headers.
    Many interal parts differences.
    Rarity. About 210 L88s vs 9500 L71s, very rough numbers, but you get the picture.
      • 43221
      Jerry-----
      DIFFERENCES:
      Cylinder heads are different
      Valve springs are different
      Valve spring caps (retainers) are different
      Connecting rods are different
      Camshafts are different
      Intake manifolds are different
      Carburetion is different
      Pistons are different
      Crankshafts are different (usually)
      Distributors are different
      Rocker arms are different
      Head gaskets are different
      Intake gaskets are different
      Oil pump is different
      Flywheel is different
      Clutch is different
      Bellhousing is different
      Pushrods are different (1969)
      Piston rings are different
      Harmonic balancer is different
      SIMILARITIES
      Block is the same
      Lifters are the same
      Timing set (cam sprocket, crank sprocket and chain) is the same
      Valves are the same
      Front cover is the same
      Oil pan is the same
      All other gaskets besides head and intake are the same
      Bearings (cam, main, and rod) are the same
      Valve covers are the same (for any given year)
      Exhaust manifolds are the same
