64 fi oilpan - NCRS Discussion Boards
64 fi oilpan
  • Richard B.
    • May 31, 1984
    • 37
    64 fi oilpan
    64 jdging manual calls for two dimpled depresionson each side my left side has three it is a six quart pan any input would help
    • 43221
    Re: 64 fi oilpan
    Richard------
    I think the "dimpled depressions" that they are talking about in the JG are those two which are on either side of the lower surface of the pan at the radius between the shallow, forward section of the pan and the sump. These depressions are created as part of the metal forming operation.
    The vertical "depressions" that you are referring to are actual features of the dies which are used to stamp the pan are intentionally created, designed-in reinforcing elements.
    • Tracy C.
      • July 31, 2003
      • 2739
      Joe is correct..but you didn't need me to tell you *NM*
