Painting 66 Dash Knobs - NCRS Discussion Boards
  • Michael B.
    • November 1, 1984
    • 57
    Anyone know any tricks on how to isolate and paint the center of a 66 dash knob?
    Mike
  • Rob A.
    • December 1, 1991
    • 2126
    Re: Painting 66 Dash Knobs
    Tape around the outside, lay the knob flat so you can spray straight down onto it, wipe the areas you don't want black with a paper towel wet with laquer thinner and a small screw driver. You can let the paint dry for awhile, it will still come off easily.
    • Tim E.
      • April 1, 1993
      • 360
      I did this just recently myself! Make a tube out of lightweight cardboard or heavy craft paper, like a toilet paper tube, that fits inside the rim of the knob. Tape off the rim itself. Mist the semi-flat paint in several passes.
      I believe the factory used a similar technique since the edge of the original paint didn't extend all the way to the rim of the knob and was slightly irregular.
