VIN plate - NCRS Discussion Boards
VIN plate
  • Andries ter Hennepe
    VIN plate
    Morning all! My VIN plate states:
    CHEVROLET DD
    194675S100048
    My question is what the " DD " stands for?
    Thank you.
  • Dan A.
    • May 31, 1974
    • 1074
    Re: VIN plate
    DD is short for delivery date. Meaning the date that the car was recieved by it's first owner.
    This date was important to the dealer when performing warranty work and is found in the owner protection booklet or warranty book as they are known in this area.The delivery date would be found in the back of the booklet with the Pro Tecto Plate data in 1965.
    Dealers were supposed to stamp the delivery date on the VIN plate but the vast majority did not.
      Re: VIN plate
      Fair enough! Thnx for the explanation.
      • Wayne M.
        • March 1, 1980
        • 6414
        Keep Posted, Andries, with that real early '65
        ... we may have some future questions on the first days of 1965 model year production, and your car, if in fairly original condition, may be able to provide some answers.
          Re: Keep Posted, Andries, with that real early '65
          It will be my pleasure to answer, where possible, any answers on your forthcoming questionary concerning 1965 Sting Ray's. My e-mail address is:
          av.terhennepe@chello.nl
          Andries ter Hennepe
            Make that "questions". Sorry for that.
              Does this work?
              Just testing to see if a picture is visible
              • Dan A.
                • May 31, 1974
                • 1074
                Re: Does this work?
                Because of the low serial number of your car it is of some interest. I failed to point thst out in my original response. Wayne has very naturally caught that. Reading you profile brings about further interest due to the cars export history.
                There does appear to be the need for a little clarification. In your initial post you give the VIN as 194675S100048 which is a convertible. In your profile you list the VIN as 194375S100048 which is a coupe. Unfortunately the fourth character in the photo you posted is not clear enough to determine if it is a 3 for coupe or 6 for convertible. The ECL BG in the trim code would indicate a convertible.
                I suspect the VIN in your profile has a type-o. For the record which is it?
                Dan
                • mike cobine
                  Re: Does this work?
                  If you look at the trim tag, you see a 467.
                  • mike cobine
                    Re: Does this work?
                    Not only does it work, you can read the numbers. Pretty cool that it is the 16th St. Louis convertible body.
                    • Greg T.
                      • January 1, 2004
                      • 136
                      Re: VIN plate
                      Didn't the VIN tags in '65 use rosette rivets?
                      • Dan A.
                        • May 31, 1974
                        • 1074
                        Re: VIN plate
                        Not the early cars. Rosette rivets came later in the year. Nolands book speaks of this on page 54. He has a list showing the first reported car with a rosette as 194675S107811 with a mix through 194675S109998. As this book is somewhat dated now I don't know what the current thinking is on the end of reound stainless stell rivets and the beginning of rosette stainless steel rivets.
                        Dan
                          Convertible or Coupe
                          Sorry for the confusion, yes it is a convertible and I changed it in my profile. Thank you for the interest in our Corvette, hope I can help answering your questions.
